Can tubes be used in tires?
Old Jan 2, 2009 | 08:43 PM
MONKMONKEY's Avatar
Default Can tubes be used in tires?
I have a 22x12-9 size wolly boogers. Tire slashed other day. Would it be ok if a tube is used?
Old Jan 2, 2009 | 09:27 PM
cherokee99's Avatar
most ATV tires are designed to be tubeless, so i dont think a tube would do so well. if its just a small amount of actual tire penitration from the slashing, i would use some SLIME-tire sealent. works well for large/small repairable holes in tires. worth a shot
Old Jan 3, 2009 | 03:29 PM
scary132's Avatar
I've used tubes many times, mostly due to bead leaks. Never had a problem.
Old Jan 3, 2009 | 11:55 PM
slamfire's Avatar
same with me. front and rear tires on my big red
Old Jan 17, 2009 | 05:29 AM
chuck_raduenz's Avatar
i agree^^^^^^^^^^^^^^^^ in my 83 atc i had tubes in all the tires. never had a prob.
Old Mar 6, 2009 | 06:13 PM
Jeff_85200M's Avatar
Hell Yeah
Old Mar 6, 2009 | 09:51 PM
firehog's Avatar
I know you can use tubes. I'm not really sure why that would be bad, though? Never used them.
Old Apr 3, 2009 | 10:18 AM
200m's Avatar
i heard tire slime eats your tire away from the inside out
Old Apr 3, 2009 | 10:36 AM
TLC's Avatar
TLC
I have been using tubes in my tires for 3 years but two tubes started leaking due to the rim cutting into the valve stem.
I,m not using tubes any longer since I found out that handy Can of "Fix a flat" or slime does not work with tubes and that stuff can save you a long walk home.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
