250sx wheels on a 185s
Old Apr 18, 2006 | 10:42 PM
Davis95's Avatar
Default 250sx wheels on a 185s
Just a quick question for anyone who does a lot of interchanging. Will the rear wheels from a 250sx fit a 185s? Thanks for the help.
Old Mar 15, 2009 | 09:09 PM
chevyhondacatdeere's Avatar
They wont.
They wont.
Old Mar 18, 2009 | 09:25 PM
MadMel777's Avatar
try this sight to see what fits
http://www.mud-throwers.com/atv_wheel_chart
Old Apr 1, 2009 | 08:53 PM
BillBlongthao's Avatar
I have a question guys, so I have a 185s also, somethings wrong with the carb cause the throttle is at FULL, it starts right up but screams cause its at full throttle the cable is good and everything and when i press the throttle down it kinda doesn't get gas and stales alittle but then when i let it go it screams, also the fuel is leaking like crazy everytime i put the gas tank back on it it leaks through the drain on the bottom of the carb and the air way??? If you guys can help me out that would be great
BILL-
Old Apr 2, 2009 | 06:20 PM
MadMel777's Avatar
when you say its at full throttle are you saying that the slide is open or that the motor is revving ? sounds like the float is stuck or not adjusted rite for it to leak gas
Old Apr 3, 2009 | 12:56 AM
yeah its at full throttle no matter what if i press the throttle or not. So i went to the dealer to get a new carb rebuild kit but the jet that goes under the floats is too small and or the clip that comes with it i don't know how to put the dang thing on, do you have any idea, the old one that was in there didn't have a clip, so i put the new one in anyways but it leaks gas like crazy still, if you could tell me what im doing wrong that would be great?? thanx BILL
Old Apr 4, 2009 | 10:38 AM
MadMel777's Avatar
do you own a manual? the slide only goes in one way..if its in backwards it will be stuck open or the idle screw can be cranked all the way in ... im not exactly sure about how the float is assembled with out looking in the book ill see if i can find mine ... but you beffant want to get one if you dont have one allready
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
