compression on 300ex?
Old Jan 4, 2009 | 12:56 AM
4x4jumper's Avatar
Default compression on 300ex?
hey guys i am looking at a 00 300ex that the guy says its not getting power to the start button. before a would buy this quad what should i do? (to make sure that is the only problem) i know i want to do a compression test but what is the comp on a 00 300ex?
thank you very much!!!!
Old Jan 4, 2009 | 01:24 AM
cherokee99's Avatar
see if honda mech knows, but im certain if compression is less then 100psi it wont run well(if at all)
Old Jan 4, 2009 | 07:08 PM
TNHondaMan's Avatar
i have a 99 300ex and my compression is at 180. when i first got it,was like 55,and it wouldnt start.has it been sitting for a while? when you do a compression test,make sure you hold the throttle wide open, and if you want to check to see if your rings are in decent shape,squirt some motor oil into where the spark plug is with a squirt gun and see if it raises it any (compression). if it doesnt,you will have to put new rings and freshen up top end,i just got through doing all this to mine. let me know more..........
Scooter's Shop
Oct 9, 2015 02:09 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
ScopeZ_
Sep 13, 2015 07:55 AM
Steeldon
Sep 9, 2015 09:38 AM
