'02 700 Sp DEAD???
Old Jan 4, 2009 | 04:58 PM
Dearlh's Avatar
Default '02 700 Sp DEAD???
[img]i/expressions/face-icon-small-confused.gif[/img]Hi all, My brother in laws SP was dead, he put in a new Interstate "wet" battery, started fine. He plowed on thursday with no issues, put it back on the battery tender, then this morning went to plow and completely dead again. No lights, no clicking, nothing!! First thing I thought of was he had the kill switch in wrong position. Had him check that , even move it back and forth a few times, still nothing. He said the battery tender was BLINKING green?? Strange, mine doesn't blink its either solid red or green. He always uses the kill switch instead of just turning the key switch to shut it off. Maybe the kill switch is worn out?? Week old battery defective??? Any fuse issues???? I'm stumped, thanks for any help.
Old Jan 4, 2009 | 05:46 PM
DCT's Avatar
DCT
Banned
The flashing green light means the battery is greater than 80% charged, and the Battery Tender is topping it off. It should go to a steady green light when the battery is fully charged.
With that said, I would check the connections to the battery and the ground to the frame. Remove, clean, and apply some dielectric grease to all connections (including the ground to the frame) and make sure everything is tightened properly.
Yes, it's possible that the new battery is defective, but the battery tender should tell you that with a steady red light, or an alternating blinking red light/green light.
Old Jan 7, 2009 | 02:14 AM
Dearlh's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]Thanks DCT, Anyone..anyone else care to advise???? thanks
Old Jan 7, 2009 | 10:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as he has stated, first place to look would be the connections as he just replaced the battery. check the voltage out put of battery to make sure its 12.5 volts or better. if so then start tracing the power to the starter. check the fuseable links in the line to see if there defective.
Old Jan 8, 2009 | 01:58 AM
Dearlh's Avatar
[img]i/expressions/face-icon-small-disgusted.gif[/img]Hi all, Talked to the bro inlaw tonight. Turns out the dumba#@ did'nt have the battery terminals tight enough to make a solid connection. I'm guess he's not as smart as I gave him credit for. I've had to come to his rescue more than a few times when he's broke down. Thanks for replies.
Old Jan 8, 2009 | 06:28 AM
DCT's Avatar
DCT
Banned
<div class="FTQUOTE"><begin quote>Originally posted by: Dearlh
[img][/img]Hi all, Talked to the bro inlaw tonight. Turns out the dumba#@ did'nt have the battery terminals tight enough to make a solid connection. </end quote></div>
There ya go... [img]i/expressions/face-icon-small-smile.gif[/img]
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
