325 trail boss help with chassis
Old Jan 4, 2009 | 09:26 PM
atv 0604's Avatar
Default 325 trail boss help with chassis
I have a 2000 Polaris Trail Boss, it looks like the frame is bent at the swing arm connection 1" to 1.5", has anyone had any luck bending it back, or do I need to scrap the frame and get a rolling chassis. If someone has a roll chassis for sale let me know?
Old Jan 4, 2009 | 11:24 PM
I bend em back in place all the time! If I'm in doubt about cracking or have one crack,just spot weld tab! I've even had tabs break off with damaged a-arms and have repaired! One place that IS tough if bent is upper frame support where strut assy goes through,BUT have had them pulled back in alignment also! I wouldn't do it IF it wasn't a safe repair,PLUS cheaper than a $600 frame! Good luck
Old Jan 5, 2009 | 09:07 PM
atv 0604's Avatar
Thanks I will give it a shot!!! The rear axle is bent at the wheel, do I need to have the dealer press a new axle in or can I do it. I really appreciate the info.
Old Jan 5, 2009 | 10:34 PM
eggenz7's Avatar
axles are easily replaced. can be taken out by removing the right side stuff off the axle. hub,sprocket and sprocket hub. then it slides out to the left
Old Jan 6, 2009 | 08:18 PM
atv 0604's Avatar
Thanks a lot I really appreciate it.[img]i/expressions/face-icon-small-happy.gif[/img]
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
