What can i do to my 250X to make it faster?
Old Feb 6, 2001 | 10:32 PM
mean250x's Avatar
I have a 1992 TRX 250X that has a FMF power core 4 and a k&n air filter. I want it to be a little faster for not much money. Yet it will still beat a 300EX I want a little more speed and power.
Old Feb 6, 2001 | 11:41 PM
Need4Speed's Avatar
Cut 4 1/2 inch holes in your air box and re-jet the carb if needed. Install a higher compression piston somewhere around 10:1 or 10.5:1 and you can still use pump gas. CT racing sells a drop in cam that's a little wilder then stock. Another option is you can also change your gearing i.e. larger countershaft sproket and smaller rear.Also try an aftermarket header, the one on the X and EX are very restrictive. These mod's shouldnt run you over $350 (don't quote me on this it's just a guess) and i know you wont be dissapointed.
Old Feb 7, 2001 | 07:03 PM
bigred250x's Avatar
First, sell the power core 4... they're completely junk. The dynos dirt wheels did prove it too. Then get something like a White Bros. Don't get a Cobra cheapo pipe like mine...mines not too bad... i out-run 300ex's but i still don't like the pipe. And what he said.
Old Feb 7, 2001 | 07:30 PM
3o0eXpAuL's Avatar
I'D say sell the power core 4 they are junk , or if you dont want to but another pipe at least take the discs and spark arester out, drill holes in your air box and rejet if you have to, i dont know what size tire you have but a smaller and lighter tire wont bog you down as much as a large tire.
Old Feb 11, 2001 | 06:31 PM
QuadDude05's Avatar
put a 350x motor in it, WHOA! u'll beat some 400ex's!
Old Feb 11, 2001 | 06:39 PM
94DGblaster's Avatar
depends on what you mean as cheap
you can go
90 for hi comp piston
90 for cam
That will be good
or you can go a little more
get the piston and the cam.
you could even bore it as much as 2mm without resleeving..and get a lil more displacement
Old Feb 12, 2001 | 01:46 AM
SNELL's Avatar
Call TC racing or Curtis Sparks they can hook you up from mild to wild (+5hp to +35hp) it depends on what you want to spend
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Backwoods_badass
Aug 3, 2015 01:34 AM
HondaR24
Jul 16, 2015 10:45 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
