trx 450 er 2007
Old Jan 8, 2009 | 06:35 AM
Jeffgaffney's Avatar
Default trx 450 er 2007
she starts great when she is cold but if i run her hard then shut off.....i have to wait about ten minutes before she kicks over. When i am done riding i always leave gas off and let her die out before putting her away.
any ideas?
Old Jan 8, 2009 | 10:23 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This engine is particularly sensitive to flooding. Never ever touch the throtle before or during a hot start. It has a pumper carb, and it will inject raw fuel. If I flood mine, I have to kick it 20 times to clear the carb out.
Also, your decompressor could be messed up????
Valves been adjusted lately?
Old Jan 8, 2009 | 10:58 AM
I have never had valves adjusted. I have a hc kit, yoshi exhaust and that is it. Not sure what decompressor unit is or does?<span class="FTHighlightFont"></span ft>
Old Jan 8, 2009 | 10:59 AM
Old Jan 8, 2009 | 11:57 AM
Red Rider
Get those valves adjusted! The most important one is the first one at 20 hours, just after break-in!!! After that, do it at least twice as often as your owner's manual suggests.
The decompressor releases compression during a start to make the engine turn over more easily. The best time to check it is at a valve adjustment.
Old Jan 9, 2009 | 12:08 PM
do all dealers perform this? what is the cost?
Old Jan 9, 2009 | 12:11 PM
Red Rider
One to two hours labor is the usual.
Old Jan 9, 2009 | 12:16 PM
thank you. what should i ask them to do with the decompressor unit?
Old Jan 9, 2009 | 12:23 PM
also, why do i need to sometimes empty the carb bowl first in order to start the bike? what issues may the quad have if i have to do this sometimes?
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
