dead cat, electrical problem
Old Jan 8, 2009 | 01:52 PM
duckdawg's Avatar
Default dead cat, electrical problem
Coming in from duck hunting the other day and I get off my cat to turn a pipe drain up. I stepped off and it went dead. Had no power anywhere. I turned the key off and on several times then out of nowhere it had power again, cranked and came home.
Got home and it does this again, this time it still has no power. Checked everything I can think of. Any thoughts?
Old Jan 8, 2009 | 02:13 PM
HeftyLefty's Avatar
Check the pod wiring, it gets pulled and stretched alot.
Old Jan 8, 2009 | 03:11 PM
duckdawg's Avatar
are you refering to the group of wire right under the handle bars?
Old Jan 8, 2009 | 05:09 PM
swampyjunior's Avatar
Yes he means the group under or along the steering column. There is a plug that can get stuck and come unplugged. It goes to the ignition key so you would loose power and it should not even pull start.
This is assuming all the connections at the battery are clean and tight.
SJ
Old Feb 7, 2009 | 10:09 AM
duckdawg's Avatar
Checked everything in the pod. Nothing loose. Still no power. Battery shows 12.6v. Please help!
Old Feb 7, 2009 | 10:15 AM
duckdawg's Avatar
BTW, I put a test light on the solenoid. I am getting nothing on the right side of it with the key on or off. The only fuse that is hot in the box is the acc fuse. Nothing else powers up even with the key on. I have check the ground, everything is ok there. Is this solenoid or the key switch, or something else?
Old Feb 15, 2009 | 07:12 AM
duckdawg's Avatar
Need to get this worked out and don't want to spend $75 an hour at my local Cat Shop.
Old Feb 16, 2009 | 09:05 PM
cragle1's Avatar
Make sure your kill switch is ok. I would then start at the ignition switch and see if your getting any power back to the starter/solenoid. If no power there, you have a bad wire or fuse. If your getting power to the starter/solenoid and it still does not turnover, either your starter or solenoid is bad. My guess would be the either the kill switch or the ignition switch.
skinnyr6
Aug 25, 2023 02:18 AM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
RedRancher
Jul 10, 2015 06:36 PM
ranvette
Jul 4, 2015 06:13 PM
