2005 Sportsman 500 won't accelerate
Old Jan 9, 2009 | 03:46 PM
PDA1's Avatar
Default 2005 Sportsman 500 won't accelerate
My 2005 Sportsman 500 (200 miles- really a clean machine) won't accelerate. It'll idle but cuts out when I try to accelerate. It has been sitting in my garage for 6 months and I haven't run it until now.
Gas is clean and flows freely to inlet side of fuel pump.
Also, the battery is won't start the rig (the battery has a little power but not enough to crank it) - I have to use the pull starter- which works perfectly.
Any ideas?
Old Jan 9, 2009 | 04:50 PM
smilenbob1's Avatar
Default Sportsman 500 won't accelerate
could have something to do with the throttle cable free play should have 1/16 of slack.
There are two contact points in the throttle control body. It has a safety device in it so when the throttle cable sticks the contacts close and it cuts power and shuts off when you release throttle.
Old Jan 9, 2009 | 05:48 PM
02magnum500's Avatar
Gets his share of deer.
EFI or Carb, Charge the battery up first.
Old Jan 9, 2009 | 05:52 PM
WAATV's Avatar
My wife has that model and it's EFI.
I agree, make certain the battery is fully charged before doing anything else. Low battery voltage could be messing with the electronics, which on an EFI machine control everything!
Old Jan 9, 2009 | 06:13 PM
PDA1's Avatar
Sorry fellas, it's a 2005 with a carb.
Old Jan 9, 2009 | 06:28 PM
smilenbob1's Avatar
would also clean the carb and make sure all the air and fuel passages are clean and fuel is coming out of the carb needle and seat.
Old Jan 9, 2009 | 07:02 PM
PDA1's Avatar
Ok.....I'll tell you a little about myself- the sad commentary of my life is "dead batteries". Well, without a charged battery on the sportsman it will not accelerate. With a really weak battery you can get it to idle but not accelerate.
I put the charger on the battery terminals while the battery was connected to the rig and I could pull start it and accelerate with no problem....naturally, while not in gear.
Thanks for the suggestions, men.
Old Jan 9, 2009 | 08:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yep these newer bikes have to have a good 12.5 volt charge it seems to make them run correctly. check your voltage output when its running and shut off. it should be at least 12.5 off and a good high 13 volt when idled around 3,000 w/ a charged battery. imo.
Old Jan 10, 2009 | 09:45 AM
PDA1's Avatar
I just let the rig sit too long. Last year I think I put 1/10 of a mile on it.
Jmuddin284
Jan 19, 2026 07:16 AM
donintennessee
Jan 8, 2021 12:40 PM
Polaris5
Aug 29, 2015 09:11 PM
donintennessee
Aug 19, 2015 02:22 PM
Shifts
Jul 3, 2015 07:59 AM
