4x4 issue
Old Jan 11, 2009 | 12:40 AM
yathink25's Avatar
Default 4x4 issue
hello everyone forum new b I got a 01 Raptor 660 and a 04 sportsman 700. Ok here is the problem the sportsman is having 4wd issues the light is on that says the 4wd is on with the switch on or of it is still on but it dont work at all also when move the shifter when I put it in park it takes it a couple of seconds to light the p light and sam with the h light when put in high. also the flashing wrnch has been on but dont know how to figure out why. can anyone help please.
Old Jan 11, 2009 | 05:21 AM
chuck_raduenz's Avatar
Default 4x4 issue
hi. the wrench is actuly a "service interval/diagnostic mode indacator
to get into the diagnostic mode:
1)turn key switch off and wait 10seconds
2)set park brake and shift the transmission to neutral
3)hold mode/reverse override button and turn key switch to on
4)release the switch as soon as the display is actived
the initial screen refers to software ver installed in your atv. this is displayed briefly.
use mode/reverse override button to toggle though the diagonstic screen.
screen
1)battery voltage
2)tach
3)awd diagnostic
this gauge indacates wether or not currnt is flowing though the awd coil. (only models with switchable awd)
4)gear circuit diagnostic
this displays the restance value (in ohms) being read at the gear input of the gauge.
5)programmable service interval
used to provide user and dealer for a rimder for routine maintenance. set a factory or dealer. can be reprogrammed in this mode.
6)mph/kph
Old Jan 11, 2009 | 08:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 4x4 issue
wrench icon like ^^he stated is just for service and he has told you how too fix that. check the connections to make sure there not corroded and put dielectric grease in the connections. this would rule out elec. input. make sure the wires going to the awd housing are not broke. if there is no issue w/ the wires or speedo, it might be a broken roller cage in the front end housing.
Old Jan 19, 2009 | 09:28 PM
yathink25's Avatar
Default 4x4 issue
if the cage is broke why would the light not turn off and now i cant get into the diag profile because the dash went out dose the inop of the dash have anything to do with the 4x4 not working
Old Jan 19, 2009 | 10:26 PM
Default 4x4 issue
if the speedo dont work, the 4 wheel drive wont work. since everything is controlled though that. the wheel sensor goes into the speedo, along with the awd switch wires.
Old Jan 20, 2009 | 09:14 PM
yathink25's Avatar
Default 4x4 issue
thank you could that be why it wasnt working corectly also the dash was on the blink
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
