No Cold Start
Old Jan 12, 2009 | 10:03 AM
labguy's Avatar
Default No Cold Start
Hey Guys, I have a 2005 KFX 400 and will not cold start. I can roll it off and allow it to warm, then and only then will it restart with no problem. If it cools off, it goes back to not starting. I had the same issue last spring and had the valves adjusted in May. Fixed the problem. I have since ridden it about 5-6 times and is now doing it again. So I have 2 questions: Is it possible to need the valves adjusted again after such a short time? If not, is there anything else you guys can think of being the problem? Thanks for your help. Don
Old Jan 13, 2009 | 07:23 PM
labguy's Avatar
Anybody????????????
Old Jan 14, 2009 | 02:03 PM
Hayashi's Avatar
Hard starting is one of the problems that can be caused by tight valves.
Old Jan 14, 2009 | 09:19 PM
jeffeosso's Avatar
get the compression tested --
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
86atc250r
Jul 28, 2000 02:40 AM
