couple of quick questions
Old Jan 13, 2009 | 05:58 PM
250Xftw's Avatar
Default couple of quick questions
on my 250x do you think i would be ok heat wise with a .40 overbore, just wondering if thats safe being aircooled? and if i went up a tooth on the front sprocket, i wouldn't have to do anything special except loosen the chain some right?
Old Jan 13, 2009 | 06:12 PM
johnboy27's Avatar
it will be fine with .40 over. heck my buddy is running a 78mm big bore in his with no problems. as far as the chain im not sure, you prob will be ok running the standard length chain.
Old Jan 13, 2009 | 06:15 PM
400exrcr's Avatar
All you have to do is adjust the chain to make up for the sprocket. But im sure your engine would heat up sitting still but as far as riding i would say you would be ok.
Old Jan 14, 2009 | 10:59 AM
JeffinTD's Avatar
Have you trashed the cylinder? I would think it would tolerate 30 or 40 over, but that increase is so slight there's really no reason to do it, unless it is to reuse a stock cylinder that is scored or worn beyond service limits.
Old Jan 15, 2009 | 12:43 AM
250Xftw's Avatar
yea it's probably gonna need a top end rebuild,havn't tore into it yet though $$
Old Jan 15, 2009 | 10:34 AM
JeffinTD's Avatar
If you don't have the appropriate micrometers, take the cylinder to a machine shop to get it measured. It might be within limits and only need a pass with a hone, or maybe needs bored to 10 over, which would let you rebore again if needed in some future rebuild.
Cole Hadden
Jun 15, 2025 09:05 AM
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
toonces
Aug 5, 2015 05:55 PM
coolguy420
Jul 28, 2015 01:54 AM
