rear brake leak
Old Jan 14, 2009 | 01:04 AM
250Xftw's Avatar
Default rear brake leak
the brake unit on the disk is leaking fluid where what looks like a bolt sticking out on the let side with a rubber grommet, so i get no pedal pressure or stopping power. What peace or part do I need to replace?
Old Jan 15, 2009 | 12:46 AM
250Xftw's Avatar
do you need a rebuild kit or is ther just a peice you can replace?
Old Jan 15, 2009 | 04:57 AM
sprayedgt's Avatar
That sounds like the bleeder valve. Check to make sure it hasn't backed it self out. You should go ahead and bleed the brakes to make sure no water got in the fluid.
Old Jan 15, 2009 | 08:35 AM
budedm's Avatar
Sounds like the parking brake adjustment screw to me. Not sure what is under that rubber gromet though.
Old Jan 15, 2009 | 09:42 AM
johnboy27's Avatar
if its not the bleeder its the seal on the piston inside the caliper. if your gonna replace it might as well do all of them. you can get rebuild kits or buy the each seal, i just rebuilt my rear caliper and got a kit. hyperparts.com i think is the website
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Sandman2.0
Jul 21, 2015 09:03 AM
