scrambler shift indicator
Old Jan 14, 2009 | 07:52 AM
charkbait's Avatar
Default scrambler shift indicator
2001 scrambler, where is the switch for the switch indicator(neutral and reverse on dash)?sometimes it work and sometimes it doesn't. is it that the shifter is out of adjustment? I think this is why i have no 4x4 in reverse sometimes because the indicator will say neutral and really I'm in reverse, when the dash says reverse the 4x4 will work.
thanks for your ideas
Old Jan 14, 2009 | 08:49 AM
eggenz7's Avatar
its on the right side of the transmission case. usually has 4 or 5 wires coming from it, its flat and about 1" wide. wires normally point down then curve back up to meet with the rest of the harness
Old Jan 14, 2009 | 08:56 AM
charkbait's Avatar
so do you think it is electrical or mechanical?
Old Jan 14, 2009 | 03:03 PM
jchunn's Avatar
Just in case this helps, you might want to take a quick read of this thread. While it is not your make or model, and the switch is in a different place altogether, it might at least give you some idea of what I got into with a similar problem. I have no idea how the switch works on the 2001 models, but I am betting there is some similarity regarding the electrical and maybe even the mechanical design.
Old Jan 14, 2009 | 07:26 PM
eggenz7's Avatar
its going to be mechanical.. if you search on here there is a good post that has the instructions on how to reset the shifter indicator
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Clint Russell
Sep 25, 2015 03:20 PM
