1999 Scrambler won't fire
Old Jan 14, 2009 | 10:35 PM
rivercity's Avatar
Default 1999 Scrambler won't fire
Hey guys, i am new to this forum and love it! Very helpful. I am having a problem with my 99' Scrambler 500 H.O. 4X4. It started back early this winter when the weather started to get colder. I first noticed the fuel valve (petcock) was leaking, i replaced it and everything was good. A couple of days later i noticed fuel leaking again but not from the valve, i looked everywhere and then found it was leaking from the tubing coming off the float bowl. I thought maybe the floats were sticking so i decided to pull the carb off, i took it apart and found that it was pretty clean but i still gave it a one over with some carb cleaner and compressed air, cleaned the jets, diaphram looks good etc. I reinstalled the carb and fuel tank etc. hooked everything up and now i cant get it to start! I pulled the plug and it is getting a spark but i suspect it is not getting enough fuel. I removed the fuel line from the carb and cranked it over to see if it was pumping fuel, a little fuel sqirted out but i am not sure how much should come out. I tried hooking a hand vacuum pump up to the fuel pump and noticed when i pump it up it doesn't hold the pressure. i took the fuel pump apart and took a quick look at the diaphram (clear plastic one) it looked good but i never really took a close look. Can these get small pinholes in them? I suspected the no start is from lack of fuel because when i sit there cranking it over and pulling the recoil trying to start it I never smell any fuel. I haven't worked on it since christmas bc my garage has no heat and it has been so friggin cold. Today was -47 celcius!!! however this weekend is suppose to be nice and i will get out there. I am just looking for any advice or anything that i can check. I really appreciate any and all advice.
Thanks
Old Jan 14, 2009 | 11:27 PM
500H.O.'s Avatar
Damn!!! that is cold.
Old Jan 14, 2009 | 11:32 PM
rivercity's Avatar
It has been like that for the last 2 weeks, so today i booked a trip to mexico!!!
Old Jan 19, 2009 | 11:42 PM
rivercity's Avatar
So i have determined the fuel pump is not pumping enough fuel and have ordered a rebuild kit from polaris. How do i prime the fuel pump once i install it?
Old Jan 20, 2009 | 08:45 PM
MECHANIKE's Avatar
hey, that pump sometimes needs to be primed! sqirt little bit of carb cleaner in the carb to fire it enogh to provide enough vacuum to prime the pump..
Old Jan 20, 2009 | 08:57 PM
rivercity's Avatar
hey thanks for the tip! Do i spray the carb cleaner as i am cranking the motor?
Old Jan 21, 2009 | 12:30 AM
eggenz7's Avatar
generally thats what your suppose to do. keeps the spray in the air instead of it landing and the air intake having to pick it back up again
Old Jan 21, 2009 | 08:32 PM
rivercity's Avatar
finally!!! i got this thing started.
Thanks Mechanike for the tip on priming the fuel pump, you just saved me 50 bucks!! turns out the old one is ok, i guess when i disconnected the fuel lines from the carb all the fuel drained out of the pump.
now that i have it running, i had to keep the throttle cracked a little to keep it from stalling, but once it warmed up really good and i took the choke off the idle speed was too low and it would stall, i increased the idle adjustment on the carb to keep it running but i have a feeling it is something else. I took it for a quick ride and it runs really well even with the choke on, could this just be the cold weather.
also it is misfiring at idle speed and low rpm's. I just put a new plug in it (NGK BKR6E gapped at .028), new fuel filter and fresh fuel.
Any ideas?
Thanks
ultangler
Nov 30, 2024 01:35 AM
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
rockinkgin
Sep 25, 2015 01:52 PM
Steeldon
Sep 9, 2015 09:38 AM
