New Odometer
Old Jan 16, 2009 | 08:12 PM
mitchetr's Avatar
Default New Odometer
Hey All,
I have a 2004 ACT I recently had the odometer break and just received a new one. I thought this would be a simple swap but. I am unable to find and easy way to be able to unplug the odometer power cord. I see from the new one how long the cord is but I am unable to get my hands in there to find it on the ATV. Besides taking the front end off. Is there an easier way?
Thanks
Old Jan 16, 2009 | 08:55 PM
catmandoo's Avatar
I have a 2004 500 and recently had to take the front rack and plastic off to change the stoplight switch and it wasn't hard at all just a little time consuming.
Old Jan 16, 2009 | 11:00 PM
bobpo's Avatar
I recently also had to replace the brake light switch. After seeing the problem I would have to encounter, I cut the two lines of the old switch and then also cut the plug off the new lines, leaving enough to have some play in it. I then placed a small section of Heat Shrink tubing on the lines. Once that was in place, I soldered
the old wires to the new and once cleaned up and sealed, I heated the shrink wrap and the job was done. Total time invested, about 20 minutes.
And it looks very professional, no extra wires showing. I did not have to remove any body parts or racks.
Old Jan 17, 2009 | 09:23 AM
catmandoo's Avatar
I thought about doing the same thing, the reason I didn't is that if it was the connection that was corroded and I cut the wires I would still have to take the front end apart. Glad it worked out for you.
Old Jan 17, 2009 | 01:30 PM
bobpo's Avatar
Your decision to do it the long way was a good one. I already knew that mine was clean so that wasn't a factor for me.
Ride Safe, Ride Sober....!
Kyle5050
Dec 13, 2019 04:25 AM
panicmanic
Sep 20, 2015 05:54 PM
Ronk407NY
Aug 18, 2015 05:52 AM
JPM
May 7, 2003 09:21 PM
jkeirste
Feb 22, 2001 10:22 AM
