03 KXF 400 idle problem
Old Jan 18, 2009 | 02:38 PM
JaysinDesignz's Avatar
Default 03 KXF 400 idle problem
I've got a 2003 KFX 400
Each time I fire up the quad it will not hold an idle after running it. I pull in the clutch & it dies. After running for maybe an hour it will finally hold an idle.
Yesterday I tried to trouble shoot the problem & noticed the fuel filter isn't hold fuel? I tried priming the system & still trickles slowly in & runs out faster that it runs in (on idle) I pulled the fuel line out on the outbound flow side & the fuel poured out) Not sure if this has anything to do with the problem. There is no real throttle response issues within that hour of running.
But, while 1st running as long as I have the quad running & giving it throttle it runs fine. It's just when I pull in the clutch it dies. Then again after about an hour its running perfect.
Old Jan 21, 2009 | 03:19 PM
Man don't all you Kooks jump on my problem all at once
Old Feb 10, 2009 | 12:50 AM
Wrenchnalldatime's Avatar
Clogged pilot jet??????????????? runs good above quarter throttle? but not below? say it aint so
Old Feb 10, 2009 | 05:48 PM
mx360snow's Avatar
Clean your carb and spray some good old carb clean in there and you will be all set.[img]i/expressions/face-icon-small-happy.gif[/img]
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
