400EX Won't Stay Running
Old Jan 18, 2009 | 02:59 PM
bsummers12's Avatar
Default 400EX Won't Stay Running
I just recently rebuilt the engine top end. And I'm having trouble keeping it running. I tore down the carb and cleaned it yesterday and reinstalled it today. Fired it up and it ran for maybe a minute and half then died.
Could the plug not be hot enough?
Could the timing be off a little bit?
Any suggestions would be great.
Thanks,
Brian
Old Jan 18, 2009 | 03:41 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Timing, valve adjustment, cam, rings, piston,,,,, could be any number of things.
I'd say it's time to take the top end off again and have a look.
I dought it's the spark plug.
Old Jan 18, 2009 | 04:57 PM
cherokee99's Avatar
how is it dieing? runnig out of gas...just cuts out..or something els? are you using any choke?
Old Jan 19, 2009 | 12:40 PM
bsummers12's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Red400EXRod
I dought it's the spark plug.</end quote></div>
I re-adjusted the valves yesterday and had it running for a good 3-4 minutes at idle and high RPM. Then it died out again. May need to make some more adjustments to the vlaves and possibly the pilot valve.
Old Jan 19, 2009 | 02:22 PM
Pirate Biker
Limping Rider!
Runs and then dies,,,, sounds like a fuel starvation problem.
How long do you have to wait until it will start again?
Old Jan 19, 2009 | 02:44 PM
bsummers12's Avatar
How long do you have to wait until it will start again?</end quote></div>
Several minutes and then it will start up.
Old Jan 19, 2009 | 04:01 PM
Pirate Biker
Limping Rider!
Definately sounds like fuel starvation.
Old Jan 19, 2009 | 04:22 PM
sprayedgt's Avatar
Sounds like the bowl is not filling up since it runs for a few minutes then when it dies takes a while before it'll start back up. Make sure your float is working properly.
Old Jan 20, 2009 | 02:21 AM
cherokee99's Avatar
agreeded, float problem. pull it apart and clean. also the fuel line from the tank and make sure there is no trash in it
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dame0927
Oct 29, 2015 10:13 PM
Bm400ex
Jun 22, 2015 09:16 AM
jayking232003
Jun 9, 2015 02:54 PM
