2007 outlaw 525irs
Old Jan 18, 2009 | 06:04 PM
trxguy9780's Avatar
Default 2007 outlaw 525irs
i finally got one, i have had it for about 6 months now. and i love it, theres one problem, i was riding at one of my buddies farm and i filled my quad up with there farm gas, and its been running like **** ever since, i drained the fuel and idk what i should do, clean the carb out?
Old Jan 18, 2009 | 07:43 PM
eggenz7's Avatar
i would drain the carb and try to drain the fuel filter. fuel that sits in an above ground tank for an extended period of time (like say a week with ethanol fuel) it started to collect water. the water separator filter will do what it can but water still gets thru. especially after the filter is already full of water
Old Jan 18, 2009 | 07:48 PM
trxguy9780's Avatar
ok thanks, so it wont have like any problems i just drain the carb, and filter and i should be god?
Old Jan 19, 2009 | 12:56 PM
95wolv's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: trxguy9780
ok thanks, so it wont have like any problems i just drain the carb, and filter and i should be god?</end quote></div>
shame on you for thinking you are God,no one is that good [img]i/expressions/face-icon-small-happy.gif[/img] you may have to pull the carb and clean it, water will cause problems, and can be a real pain to get out of all the passages, you may need to blow them out with carb cleaner and an air gun in case any dirt made it in as well.
BYC
Sep 25, 2015 02:10 PM
Sep 23, 2015 06:23 AM
poutlaw525
Sep 9, 2015 03:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
