How to install a back up light on Renegade?
Old Jan 18, 2009 | 06:19 PM
rincon all out 's Avatar
Default How to install a back up light on Renegade?
Looking for info on how to install reverse light when renegade is shifted into reverse does anyone know what wire to tap intp for this mod? thanks Craig
Old Jan 18, 2009 | 08:47 PM
brian 68's Avatar
a detailed service manual should have the wiring diagram, other than that if you have a [dash] light trace the wire back , you could prob use that lead to a relay. since there wont be enough juice to run them off the light feed . the light feed just switches
the relay on ,you use a seperate bat feed hope this help's
Old Jan 18, 2009 | 08:49 PM
thanks that was the line i was thinking of going just wanted to see what everyone sugg.
Old Jan 30, 2009 | 10:45 PM
stray's Avatar
it appears to be a real pita on the can ams, since there isn't an indicator light on the display and the manual (at least the manual i have) doesn't have wiring diagrams. i've seen it done on other forums by adding a switch in the "R" slot where the shifter rod goes. there's also oem parts (for the european version) that have a taillight fascia with openings for reverse lights.
generalpops
Jun 5, 2015 08:23 PM
Dieseltrash
Jun 1, 2015 06:53 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
