Back up light install?
You will have to run a power wire to the light and tap the ground into the gear position switch wire for reverse. 3 wires coming from the gear position switch are green, light blue with a white stripe and the other wire is light green. The green wire is reverse. Like I said, hook the reverse light ground wire to this green wire
----- Gimpster -----
