Back up light install?
Old Jan 18, 2009 | 06:21 PM
rincon all out 's Avatar
Default Back up light install?
Does anyone know of a hot wire to install a reverse light when my 07 Rincon is shifted into reverse.
Old Jan 19, 2009 | 03:39 PM
Gimpster's Avatar
You will have to run a power wire to the light and tap the ground into the gear position switch wire for reverse. 3 wires coming from the gear position switch are green, light blue with a white stripe and the other wire is light green. The green wire is reverse. Like I said, hook the reverse light ground wire to this green wire
----- Gimpster -----
Old May 21, 2009 | 10:52 AM
drscotch's Avatar
Thanks Gimpster,
Would the same be true for a 2008 Rubicon?
There is a Green wire on the R terminal on the gear position switch in the wiring diagram.
Thanks
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Dieseltrash
Jun 1, 2015 06:53 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
