1991 Kawa KLF300 Carb help.....
Old Jan 19, 2009 | 09:17 PM
YamahaRacer447's Avatar
Default 1991 Kawa KLF300 Carb help.....
I went to start my four wheeler today (1991 kawasaki klf 300 bayou)... its been about 2 months or so since i last rode it and when i went to start it it wouldnt start. i knew i wasnt getting any fuel so i put some more it in cause i noticed it was low. well when i was pouring fuel in it was comming right back out of a line on the carb. the line is attached to the carburator bowl at the bottom (this is where fuel was comming out of) the line was attached to the bowl and is about a good 9" in length and was comming out the other end. does anyone know where that line is supposed to attach or what it does????
Thanks
Old Jan 20, 2009 | 08:48 PM
Mojaveman48's Avatar
IT SOUNDS LIKE YOUR FLOAT IS STUCK OPEN BANG IT WITH THE END OF A SCREWDRIVER A FEW TIMES IF THAT DOESNT WORK WELL THEN YOU WILL HAVE TO REMOVE THE CARB BOWL AND MOVE THE FLOAT MANUALY
Old Jan 20, 2009 | 09:33 PM
Sisco1957's Avatar
You could try removing the fuel line at the petcock and blow compressed air (not to much pressure) into the carb. Ssometimes that will force the needle to unseat.
Old Jan 20, 2009 | 10:25 PM
So would the float be stuck in the up or down position? why would a stuck float let fuel pour out of the bottom of the bowl through that line??? is the line just there for draining purposes??
Thanks for the input
Old Jan 20, 2009 | 10:54 PM
its for draining the bowl but there also an over flow tube in there that by passes the drain screw
Old Jan 20, 2009 | 11:14 PM
Sisco1957's Avatar
Sorry I misread your post. You are right about the needle not closed because fuel is getting into the carb. There might be some trash not letting the needle seat. The float could be stuck in the down position. I have had pretty good luck by loosening the drain screw to empty the bowl and spraying carb cleaner into the fuel line to fill the bowl. I usually let it sit overnight before draining. Sometimes it will clean it enough to work and save removoing the carb.
Old Jan 21, 2009 | 09:34 PM
i am thinking about just taking off the carb bowl and inspecting the float and everything. hopefully this will work i will try it tomorrow its too cold in my garage to mess with it tonight
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Gnuters
Jul 19, 2015 10:03 AM
