honda 110
Old Jan 20, 2009 | 08:30 AM
hondaman300ex's Avatar
Default honda 110
should the headlight light up when i try to crank?.if the switch is turned to on position?.getting an orange spark now when i had blue spark with brand new plug. could my plug be bad?
Old Jan 20, 2009 | 08:11 PM
honda185s's Avatar
Default honda 110
Yes your headlight should start to light up as you crank the engine, if the light is turned on. So what your saying is when you just got a new plug your spark was blue and now its orange? How long ago was this? It is a good idea to replace your plug every now and then. What is it like $4 for a pack of 2?
Old Jan 21, 2009 | 08:08 PM
Default honda 110
headlight dosent light up do you think it could be the coil
Old Jan 21, 2009 | 11:01 PM
SMFREY's Avatar
Default honda 110
What year 110 are we working on
Thanks
Ray
Old Jan 22, 2009 | 07:56 AM
Default honda 110
its an 82 model.i purchased a used motor from ebay. got everthing ready and it cranked an ran fine.next morning cranked it an was warming it up and it died out and will not crank. i also noticed that when i pull the rope the headlight dosent light up.could it be the primary or secondary coil? i need all the help i can get
Old Jan 22, 2009 | 11:21 AM
SMFREY's Avatar
Default honda 110
I will look up the test for the windings tonight
That is a CDI ignition
Is the bike also an 82
Ray
Old Jan 22, 2009 | 05:26 PM
Default honda 110
yes bike is an 82 model and im getting fire but its orange now when it was blue.but my headlight dosent come on when i crank it. ive got a puller for the flywheel and another set of coils.just need to know how to check them to see if they are good
Old Jan 23, 2009 | 08:39 PM
honda185s's Avatar
Default honda 110
Here is a link to the service manual,
http://72.52.143.80/~trikes/at...ier_servicemanual.pdf
What you want to do is test the resistance on the connections at the stator plug. You will need a Multi Meter.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
