dead explr 400
Old Jan 21, 2009 | 01:32 PM
crashnrole's Avatar
Default dead explr 400
need some help...was riding along and it died..sonded like the exhaust got real loud and then quit...tried to start and it wouldnt turn over and the pull start would not pull...after a couple trys it would turn over but not start.....pulled the plug and it is sparking...I do have compression when i hold my thumb over the hole for the spark plug.....not sure if its enough...carb has gas..check my counter balance oil and it was not showing on the dip stick....any ideas???
Old Jan 21, 2009 | 01:36 PM
02magnum500's Avatar
Gets his share of deer.
Sounds like you seized the engine..Did you have the oil injector tank full of injector oil? Could have leaned out some how.
Old Jan 21, 2009 | 01:50 PM
crashnrole's Avatar
injecter tank was full...it will turn over and there is compression......
Old Jan 21, 2009 | 06:01 PM
Wenty's Avatar
Sounds to me like the piston skirt broke off. Dropped down in the ower end and lodged so you couldn't pull it over. After a few tries you dislodged the chunks of skirt...but it's still down there...not good. Don't try starting it anymore, you'll cause more damage if this is the case.
Old Jan 21, 2009 | 07:05 PM
eggenz7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Wenty
Sounds to me like the piston skirt broke off. Dropped down in the ower end and lodged so you couldn't pull it over. After a few tries you dislodged the chunks of skirt...but it's still down there...not good. Don't try starting it anymore, you'll cause more damage if this is the case.</end quote></div>
i agree completely. 2 strokes use the skirts for timing. if one isnt there then the "vavle" timing is essentially off. take the intake off and the exhuast manifold off. then look inside the two holes while slowly turning the flywheel. should be able to tell if a skirt is broke
Old Jan 21, 2009 | 07:06 PM
rexcramer's Avatar
When they are running, quit, and all of a sudden wont turn over, that is usually real bad. I bet you seized the piston, and when the engine cooled down the piston let go and you could pull it over again.
Your piston is most likely scored pretty good and I bet a compression test will show low compression. Get your wrenches out
Old Jan 22, 2009 | 12:32 PM
crashnrole's Avatar
ok....thats what i thought...thanks...will post what i find after tear down..
Old Jan 23, 2009 | 07:53 AM
midnightxplorer's Avatar
Make sure you check the engine chase for cracks it happend to me twice....
they dont like water.....LOL...I found this out plenty of times.
Old Feb 9, 2009 | 09:18 AM
crashnrole's Avatar
Update: I took it to a guy I know for repairs. The piston broke/shattered/came apart. I also got a hole in my crankcase. Not sure if it's worth fixin. Thinking about parting out and starting over.
This hasent been a good atv year for me, My 700 was stolen and now the 400. maybe I'll get a mountain bike..............
Old Feb 9, 2009 | 05:05 PM
rexcramer's Avatar
Sorry to hear that. I wouldnt try to repair that crankcase, it would be easier just to put another motor in.
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
