04 Grizzly 660 throttle problems
Old Jan 21, 2009 | 03:11 PM
boosted_d16's Avatar
Default 04 Grizzly 660 throttle problems
Every time I turn my handle bars left my Grizzly throttles by itself, I guess the throttle cable is to short or something. It will also do if it I push or pull the throttle cable on the handlebars. I found a few things on it when I searched but no fixes or anything. This is getting to be pretty dangerous to many, What will fix it? THanks -TJay
Old Jan 21, 2009 | 06:00 PM
87 warrior's Avatar
either your throttle cable is too short or it's not run right through the frame to the carb. or it's getting hung up somewhere.
Old Jan 21, 2009 | 07:18 PM
Yes I know that. But from what I hear, a lot of 03-06 Grizzlys do it. From what I can see its not hung up on anything.
Old Jan 26, 2009 | 05:02 PM
Any help at all? THe throttle cable isnt hung up on anything just too short I'm guessing. Will a new throttlecable cure this?
Old Jan 26, 2009 | 06:09 PM
petgriz's Avatar
Did you just get the atv or did you have it for awhile and then it just started happening?
I would first check the free play at the thumb throttle and see if it's adjusted properly. There should be about 1/8" play.
Then turn the handle bars and see if the cable is being pulled at the carb end or the thumb throttle end. From this you can see where the cable may be binding on something. You may have to remove the cover that covers the throttle linkage at the thumb throttle.
There is also another adjustment on the throttle cable that's close to the carb end of the cable that you may be able to lengthen abit.
Old Jan 26, 2009 | 06:55 PM
I adjusted it and made it a little better. But just at the thumb. I bought the ATV and it always have done it since then. The guy i bought it from was the first owner and said it has done it for as long as he can remember. I'll try taking the thumb cover off and see whats under there and also at the carb.
Old Jan 29, 2009 | 02:47 PM
YTM_225_DX_LOVER's Avatar
My TTR did the same thing. what happened is the throttle cable sheathing wore trough where it rubs on the frame. Then every time you turn, the cable kinks and pulls. Sometimes it'll stick like that and then you have a Redneck Cruise Control. So check the cable over to make sure its in good shape
Old Mar 8, 2009 | 07:30 AM
sharktooth's Avatar
my problem was that the cable was routed over the cover at the handlebar and not under it like it should be,causing it to bind or kink. Let me know if this is your problem.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
Sjrpp
Jul 5, 2015 09:04 PM
