2001 Xplorer 400 4x4 2 stroke coolant ?????
Old Jan 23, 2009 | 11:12 AM
thunderxxx101's Avatar
Default 2001 Xplorer 400 4x4 2 stroke coolant ?????
I own a 2001 400 4x4 2 stroke and I have coolant coming from the tube that comes off whats looks to me like the top side of the crank case. Not sure if expalined right. I know that is were the counter balance is and this tube is on the top side of the case. I add coolant to max level and as soon as engine warms up the coolant starts coming out of this tube which points upwards and the coolant needs refilled. Not sure if it is head gasket, cracked cylinder sleeve or maybe a counter balance problem.
Thanks all,,,,,,,,,,,,,,,,,
Old Jan 27, 2009 | 06:20 AM
I know I am new to this forum and I may not describe my problem very well but I do need some help or just the right place to start looking. I do see a lot of question being asked and answered so can somebody please give me a little help here were to begin.
Thanks all.........
Old Jan 27, 2009 | 07:29 AM
xplorerman's Avatar
did you check your conter balincer oil the dipstick is under the carb on the engin block you need a long flathead screwdriver to remove it then check the recoil housing for the coolent ps sorry it took so long for you to get help i hope this is what you were looking for
Old Jan 27, 2009 | 10:06 AM
Thanks for reply,,,,,,,,,,,,,,,,,when you say recoil housing are you talking on the pull start. You typed check the recoil housing for the coolant ps,,,,,,,what are you meaning "ps".
Old Jan 27, 2009 | 01:12 PM
Kvmjwisefamily's Avatar
yes it is the pull start the water pump is behind the pull start it it problay leaking when the motor get to operating temperature
Old Jan 27, 2009 | 02:01 PM
xplorerman's Avatar
yes i ment to sae the pull starter hope you get it fixed
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
exmotocrosser
Sep 26, 2015 08:18 AM
rockinkgin
Sep 25, 2015 01:52 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
