noisymotor
Old Jan 27, 2009 | 03:10 PM
lynnedon's Avatar
Default noisymotor
we have a 2005 honda rincon 650 that sounds rattly when running. we are using a synthetic 10/40in it. any suggestions?
Old Jan 27, 2009 | 03:11 PM
cherokee99's Avatar
Default noisymotor
if the rattel if comeing from the top end, you need a valve adjustment
Old Jan 27, 2009 | 03:17 PM
lynnedon's Avatar
Default noisymotor
thanks. is this also the problem if it is burning oil or is that something different?
Old Jan 27, 2009 | 04:14 PM
JeffinTD's Avatar
Default noisymotor
That would be something different, like maybe valve seals or rings.
How much is it burning? Visible blue smoke? Has it ever been sank?
Old Jan 29, 2009 | 11:53 AM
DavidXP's Avatar
Default noisymotor
does the rattle go away when it gets warmed up?
Old Jan 29, 2009 | 04:04 PM
lynnedon's Avatar
Default noisymotor
just had valves adjusted as they said they were out. they said using oil was because of this. mechanic said still a noise coming from motor. thought maybe crank or rod going but unless we spent another 700.00 plus fix up, to find out they not sure. just ran machine and noise seems to go away and come back off and on
Old Jan 29, 2009 | 04:38 PM
HondaMechanic's Avatar
Default noisymotor
The TRX650 has a weak camchain tensioner which is the same " HAO " camchain tensioner since the 1985 ATC250 BigRed , we've changed several ...
Old Jan 29, 2009 | 06:45 PM
JeffinTD's Avatar
Default noisymotor
The cam chain tensioner does seem to be a frequent topic on these.
I don't buy the dealer's claim that the valves being out of adjustment resulted in the oil usage, however.
Old Jan 30, 2009 | 10:03 AM
lynnedon's Avatar
Default noisymotor
is this tensioner to do with the crankshaft(sorry dumb woman here). took it out for ride and seemed to quiet down abit however now we are not sure if we hear a valve tic. still smokes when warmed up. is the tensioner hard and expensive to fix? thanks for everyones help
Old Jan 30, 2009 | 09:19 PM
JeffinTD's Avatar
Default noisymotor
The tensioner just takes up the slack in the chain that drives the cam shaft. If it doesn't work properly, the chain can smack around in there.
If you are also hearing valve noise, checking the valve lash would be a good idea (if it hasn't been done recently).
Neither of these would cause the motor to burn oil, however. Also, a bit of mechanical noise is normal on most any atv engine.
How much oil is it using? How many miles on the machine? What kind of oil is in it? Has it ever been sunk (mud and/or grit got into motor)?
There's no dumb question, and working on ATV's isn't magic or anything. Getting a factory service manual, and maybe having someone experienced to look over your shoulder when you first start doing your own work would be a good idea.
