Bad Stator / Still spark?
Old Jan 28, 2009 | 06:11 AM
apopka_ed's Avatar
Default Bad Stator / Still spark?
Is it possible to have a spark, but a bad stator? I have a good spark, but it wont start. The stator doesnt test withing range w/ ohm meter. I just dont understand why theres a spark?
Old Jan 28, 2009 | 07:03 AM
Kerbbirds's Avatar
If you have spark, fuel and compression it should run, it is possible to have a bad stator and still have spark though. Is it sparking at the right time? Is the timing right? Is the cam shaft worn ? Take the valve cover off and whatch the cam and rocker arms while it turns over, see if one is not working like the rest.
Old Jan 28, 2009 | 04:12 PM
<div class="FTQUOTE"><begin quote>Originally posted by: apopka_ed
Is it possible to have a spark, but a bad stator? I have a good spark, but it wont start. The stator doesnt test withing range w/ ohm meter. I just dont understand why theres a spark?</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] Also can remove flywheel nut and see if key sheared and flywheel has moved on crank,throwing out of time,but still good spark! Had a couple 500 sportsmans do this! Just a thought!
scram5050
Sep 3, 2015 05:06 PM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Aug 1, 2015 04:05 AM
