Lights dim with throttle
Old Jan 28, 2009 | 09:27 AM
slikjr's Avatar
Default Lights dim with throttle
I am having an issue with my headlights dimming. When I am at idle, they are full bright. However, when I give it any throttle they dim out a bit. I'm confused as to why this is happening. You would think it would be the opposite (dim at idle) if it was a charging issue. Could it be the battery is just weak? I did get a bit of water in a headlight last year and I have new ones on order but...
Anyone with some expertise beyond mine or have had a similiar situation, please post! It's just one of those little things that drives me nuts!
A guy at work here suggested the "Voltage Regulator". This might make sense because it happened after some serious water crossings. All other electrical stuff works just fine though. Anyone tell me where along the line to find the voltage regulator? I'm not familiar with it on my bike.
Any ideas at all. Thanks in advance
Old Jan 28, 2009 | 09:44 AM
MECHANIKE's Avatar
that would sound right,considering it happened right after crossing,check volts while runnin,12.5>13.8v.
Old Jan 28, 2009 | 11:37 AM
jchunn's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: slikjr
</end quote></div>
It is usually under the "hood"... the plastic piece that sits between the radiator and handlebars, mounted to the frame somewhere. If you look at the microfiche on any parts site, it is usually on the slide called "electrical/taillight" or something like that.
Old Jan 28, 2009 | 01:58 PM
slikjr's Avatar
Ok, thanks. I'll check the "microfliche" and see what I can find. I'll take it a look at it. I'll pull it all apart, clean it up, dielectric grease it and put 'er back together. See if that makes any difference.
I was also thinking possibly a ground. I am going to pull all my grounds off, clean them up and put them back on. Thinking maybe if there is a bad ground the increased throttle causes more interference and is messing with it.
If it's not either of those things, I'll up poop creek because I hate picking apart every electric connection looking for something! Grrr. I'll keep my fingers crossed!
Thanks for the help thus far. Keep it coming if anyone thinks of anything else!
scram5050
Aug 30, 2024 01:39 PM
skinnyr6
Aug 25, 2023 02:18 AM
mtdewmn
Jan 19, 2017 12:13 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
