need more power ,explorer 400l
Old Jan 28, 2009 | 10:24 PM
hoowaa's Avatar
Default need more power ,explorer 400l
hi there . my 98 explorer lacks power . bogges down and loses power about 3/4 throdle flat out or up hill any one know of some power addons to give it more pep .. reed valves or big bore kit ..do they help ..any help would be great
Old Jan 28, 2009 | 10:48 PM
Wenty's Avatar
If your loosing power or bogging down sounds like you have a fuel or clutching issue. Clean and inspect the carb...inspect the clutch's for starters.
The 400 xplorer when running correctly isn't short on power or speed and should rip!!
Old Jan 28, 2009 | 10:58 PM
hoowaa's Avatar
thanks for the advice ill give it a try
Old Jan 29, 2009 | 08:17 PM
ftwflh's Avatar
First thing check the secondary clutch ramp buttons.ThenCheck the compression first.If below 100psi do a topend and then replace the reeds and clean the carb.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
