2000 foreman shift problem
Old Jan 30, 2009 | 06:04 AM
Hondaray's Avatar
Default 2000 foreman shift problem
Hey to any one who can help would greatly be appreciated...I have a 2000 foreman es it sat for while with the piston and rings gone we got that all fixed and runs great... but there is a shift problem with the es if you are driving and it stays in the same gear for say 10 seconds it stays in that gear and won't shift up or down until you shut the bike off and restart it... or if take a wrench and use the manuel shift on the motor. You can run it through the gears when it is just siting there ideling..Oh and when it sticks in gear on the dash were it shows what gear it is in there is just a line across it. Any ideas Thanks Ray.
Old Jan 30, 2009 | 08:32 AM
TLC's Avatar
TLC
Not sure if this info will help but its worth a look.http://forums.atvconnection.co.../8/threadid/553125.cfm
AND
http://forums.atvconnection.co.../8/threadid/553569.cfm
Old Jan 30, 2009 | 10:27 AM
Hondaray's Avatar
I forgot to mention that the spedometer is not working either , just wondering if that has anything to do with it?
Old Jan 30, 2009 | 11:10 AM
HondaMechanic's Avatar
Yes the speed sensor is one of the ESP inputs ...
Old Jan 30, 2009 | 02:05 PM
Hondaray's Avatar
any idea why the speed sensor is not working?
Old Jan 31, 2009 | 01:00 PM
Gimpster's Avatar
In my eyes, Honda went with a crappy sensor design on the sensor when they designed the engine.
I have replaced a few hundered of them over the years
First sign of them going bad is holding the quad wide open in 3rd gear. You will see the speedo weard out and will not be able to shift thereafter with the electric shift until the quad is stopped, manually shifted into neutral, key off and then back on to reset the ECM
----- Gimpster -----
Old Feb 2, 2009 | 02:00 PM
Hondaray's Avatar
so do I have to change the whole thing where it bolts onto the engine ifso any idea what the price of them are thanks
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
honda71
Jul 8, 2015 02:13 AM
