Flywheel
Old Feb 3, 2009 | 07:00 AM
apopka_ed's Avatar
Default Flywheel
How do you keep the cotton pickin' flywheel still when getting the bolt/flywheel off?
Old Feb 3, 2009 | 08:45 PM
Kerbbirds's Avatar
Default Flywheel
easiest to use an impact, but i think they make a flywheel holder for it, u also need a flywheel puller, another trick to hold the flywheel is take a prybar through the primary clutch and that holds the motor in place as well
Old Feb 4, 2009 | 03:01 AM
MrMarty51's Avatar
Default Flywheel
Some times if You do`nt have an impact You can have someone hold the Flywheel from turning and then strike the wrench with a hammer.
As stated above"You will still need a puller to remove it" once the nut is off.
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
