XP Wheel spacers ??
Old Feb 3, 2009 | 11:54 AM
Stealth Hunter's Avatar
Default XP Wheel spacers ??
Well I have decided to go with the 11" XTR's on the back, instead of the 9" all around.
HO you talked me into it, as the front stockers did not look right on the back. The 9" XTR's most likely won't either. Thank you for the heads up and the cost saving, HO!!
What are the best kind of spacers to run? I only want 1" spacer.
Where should I buy??
Should I put spacers on all four corners, to match??
I may try to mod my swaybar (at a later date), but I want to try the spacers for know, so any input would be appriciated.
Old Feb 3, 2009 | 12:10 PM
Hotdogmb's Avatar
spacers will change the way it steers if you use them.
Old Feb 3, 2009 | 01:26 PM
Thanks Hotdogmb,
That is exactly why I am debating not to install them on the front and go with rears only.
Old Feb 3, 2009 | 03:25 PM
DavidXP's Avatar
you only need spacers on the rear and the polaris dealer has them i paid 220 canadian installed.......If you read highoctanes post hes deviced a way to do it quite easily without spacers!!!! much better because of them my quad dosen't fit in my truck it adds that much(i have a styleside) IMO i wouldn't use the spacers!!
Old Feb 3, 2009 | 04:10 PM
HIGHOCTANE's Avatar
As said,If you use the spacers on the front they will increase steering effort and kickback,..if you only use them on the rear be aware of the increased rear track,ie the rear may not fit where the front does.
These look decent but I can't personally vouch for them.
http://cgi.ebay.com/ebaymotors...Q5fPartsQ5fAccessories
Edit-BTW you can probably have the sway bar bent by the time you figure out which spacers you want,lol...
Old Feb 3, 2009 | 06:28 PM
triplggg's Avatar
I have them on the rear only,no problems.I'm going to do HO's mod at a later date.Been working 13 days on one off up to twelve hours aday.
The link to eBay is the guy I got them from.You could go right to his website:www.superatv.com
Old Feb 3, 2009 | 06:33 PM
Rutcutter's Avatar
Save your money and do the HO mod to the swaybar and buy something else with that cheese..
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
