1986 trx200sx
Old Feb 3, 2009 | 04:27 PM
hopy-dah's Avatar
Default 1986 trx200sx
I removed the flywheel to repair the starter clutch and after reasembly I do not have any fire. I double checked all of the wiring and they are properly plugged into their appropriate color coded wiring. The generator is functioning as it will light the neutral position light. How do I check the ignition circut to find the problem?
Thank You for your help
Old Feb 3, 2009 | 06:22 PM
HondaMechanic's Avatar
Old Feb 3, 2009 | 08:46 PM
budedm's Avatar
It's prolly a CDI box. I had to replace mine on the same bike.
Old Feb 4, 2009 | 12:01 PM
hopy-dah's Avatar
Thank You very much for the info. I will do the trouble shooting and see if I can figure out the problem. It had good fire before I fixed the starter clutch so I must have messed up something. I hope it is not the cdi box. I will let you know what I find.
Thank You again
Old Feb 4, 2009 | 12:50 PM
You don't have to remove the pulse generator to service the starter clutch but the old wires may have broke inside the insulation if they were bent much .. I would check the wires and do the tests for the exciter winding & pulse generator ..
Old Feb 5, 2009 | 09:11 AM
hopy-dah's Avatar
Good News! I followed the trouble shooting instructions and it lead me to the run stop switch. Everything else checked out fine. I cleaned the switch and the old girl is running again.
"Thank You for your help
1986Vmax540
Jul 9, 2021 09:53 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
Sep 1, 2015 11:59 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
