Need advice on kfx700
Old Feb 5, 2009 | 10:25 PM
dock_09's Avatar
Default Need advice on kfx700
I realy need help my kfx 700 THE rearbrakes are locked up it will still go butt alot
of drag
Old Feb 5, 2009 | 10:49 PM
stillV1's Avatar
Have you tried to ride it or is it just real hard to push, because the fluid in the rear wet brake system thickens up in cold temps. Mine gets really hard to push when the weather gets real cold.
Old Feb 5, 2009 | 11:12 PM
Hayashi's Avatar
I can push around my 700 no probem at 25 F weather in neutral. If your rear wet brake is sticking, check/adjust parking brake cable first. If no help, then drain the wet brake oil and inspect for any metallic debris. If found, the clutch packs inside the rear gear case needs to checked/replaced.
Old Feb 5, 2009 | 11:18 PM
stillV1's Avatar
Hayashi is probably onto something...he is a little more experienced with these things than I am...in cold weather I can still push it around but I guess it seems alittle harder to me...Thanks for clearing this up Hayashi[img]i/expressions/beer.gif[/img]
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
