Found my problem, now how to fix??
Old Feb 7, 2009 | 09:44 AM
02popo's Avatar
Default Found my problem, now how to fix??
My no spark problem has been pinpointed. While removing the flywheel, one of the bolts was threaded in far enough that when the flywheel turned it knocked of one of the stator wires from the stator. So no spark.
I used a soildering iron to try to clean and reattach the wire, but what i have found is no wear to hook the wire to. What does the stator wires soilder too??? All i see is the copper windings on each post from the stator.
THANKS!!!!
Old Feb 7, 2009 | 10:36 AM
Kerbbirds's Avatar
probably gonna have to replace the stator, it's so hard to get everything the way it was when a coil breaks on a stator, it's nearly impossible.
Old Feb 7, 2009 | 10:49 AM
02popo's Avatar
I was hoping to get away with just reattaching the wire since it just came off. Just can not figure out how it attaches or to what.
Old Feb 7, 2009 | 11:08 AM
HIGHOCTANE's Avatar
Is the "goo" possibly the rubber grommet where the wires come through the housing/block? Look on the outside for the wires going into the housing.
Old Feb 7, 2009 | 02:12 PM
02popo's Avatar
No, im talking about the two wires that actually connect to the stator, on the stator itself.
THANKS!!!
Old Feb 7, 2009 | 02:26 PM
HIGHOCTANE's Avatar
Ahh...If I would have read closer I would have known that,lol...
They connect inside that coil/bobbin..under the goo and the wrap is a coil of wire..that is about the extent of my knowledge with the stator...i'd buy a new one,lol..
You might even be able to buy just that bobbin and replace it?
Old Feb 7, 2009 | 02:41 PM
02popo's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: HIGHOCTANE
You might even be able to buy just that bobbin and replace it?</end quote></div>
What is a bobbin??
Old Feb 7, 2009 | 03:26 PM
HIGHOCTANE's Avatar
The bobbin is the coil of wire and the part that it wraps around...
http://cgi.ebay.com/ebaymotors...3596037QQcmdZViewItem
I can't vouch for how well replacing them works or holds up. I've never tried it.
Old Feb 7, 2009 | 03:37 PM
02popo's Avatar
Gottcha.
Anyone know how the bobbin connects to the twp lead wires?? Is there a specific tab/terminal/wire hanging out??
All i see is copper coiled around the "bobbin".
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
