Scrabler 4X4
Old Feb 7, 2009 | 06:05 PM
scrambler50's Avatar
Default Scrabler 4X4
Need some tech assistance on a 2000 Scrambler 400 4X4. This is my daughters machine not abused. Noticed the left fromt axle shaft it turning but not the wheel. Are there any common issues with the front hubs and is it hard to repair.
Thanks
Tom
Old Feb 7, 2009 | 06:45 PM
Change hub fluids first,if still have problem,you might check that elec connections for this side is ok.If this doesnt help may have to check into hub,especially the black armature plate,bearings and hilliard condition.
Old Feb 7, 2009 | 06:46 PM
ftwflh's Avatar
With the 4x4 on the right pulls and the left doesnt. right?First thing to check would be hub fliud.If fluid level is ok then check for a broken wire going into the strut.If wires are not broken take hub apart and check current at amature.
Old Feb 7, 2009 | 10:44 PM
Thanks for the suggestions. Did not know there was hub fluid. Owners Manual states remove set screw and see if there is any hub lub. Is this hub lube a dealer only fluid or is there something else comparable? Thaks Tom
Old Feb 8, 2009 | 07:35 AM
ftwflh's Avatar
You can use type F automatic tranny fluid to get by
stendori
May 10, 2012 12:11 PM
qkjunky
Mar 18, 2008 01:31 PM
BigDaddy331
Jan 3, 2006 01:07 AM
mRt86
Aug 28, 2005 12:40 AM
BigD500ho
Mar 30, 2003 01:10 AM
