battery draining quickly
Old Feb 8, 2009 | 11:24 AM
rouxster's Avatar
Default battery draining quickly
i just put a brand new battery in my ac 300 4x4. today i started it w/ no problems. then i turned it off & tried again. battery dead. i did notice that the rectifier-regulator part was blistering hot. does that mean that i need to replace it?
Old Feb 8, 2009 | 05:26 PM
mudslinginfool's Avatar
Does it in the Mud!
i had a 99 and it did the same thing.It was infact the regulater, an $80.00 part. my neighbor had the same thing on a 2000 300. Im not saying for sure thats it ,but they all sound like they have the same thing going wrong with them.
Old Feb 8, 2009 | 09:48 PM
rockout's Avatar
i think i have the same problem on my 99 ac 300. i put a new battery in it a few weeks ago and it was dead the other day. i even have an on board battery charger, but did not keep it plugged in. i have a draw on the battery that is draining the battery down after a few days. after unplugging the regulator, the draw is gone. i believe there is an internal diode that keeps the battery from draining down.
Old Feb 10, 2009 | 03:14 PM
swampyjunior's Avatar
Does sound like the regulator. One way to checl would be to unplug the regulator and leave the battery connected to see if there is a short. You might also do an Ohm test to see if current is just passing through the regulator and grounding some place else.
I have seen and rad about a lot of issues withthe regulators on the older AC's and I am wondering if the high heat output fromthe engine is negatively effecting the regulator.
SJ
Cummins Driver
Sep 11, 2019 01:22 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Ronbo6270
Aug 6, 2015 11:54 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
