my banshee overidles!
Old Feb 9, 2009 | 08:34 AM
luisitoelmejor's Avatar
Default my banshee overidles!
Help my banshee overidles! Whenever i push the choke in all the way after warming the engine up it overidles extremely high. I've tried playing around with the idle screw on the carburetor but it makes no difference. At first i thought it was the air box cause it didn't have a filter in it but still that made no difference. Does anyone have any idea what else it might be and why it only does this when the choke is pushed all the way in? Thanks.
Old Feb 9, 2009 | 08:44 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
You probably have an air leak somewhere. Check your lines for a small hole somewhere.
It's not a good idea to run without a filter unless you just have to when working on it.
Old Feb 9, 2009 | 05:06 PM
Dune Rat 2008's Avatar
your throttle cable maybe gettin hung up somewhere to causing it to rev without using the throttle
Old Feb 9, 2009 | 05:09 PM
dalguard's Avatar
With no air filter you are getting your carb and valves very dirty. Not to mention shortening you engine's life span! You need to have your carb cleaned.
Old Feb 9, 2009 | 08:01 PM
Sidewinder500's Avatar
you sure you were adjusting the idle on your carbs or maybe playing with the carb sync settings?
Old Feb 10, 2009 | 08:31 AM
it was the idle screw but its broken so im thinking that may be the problem
Old Feb 10, 2009 | 08:32 AM
I checked to see if the throttle cable was hung up anywhere but it was fine and in postition
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
