warrior acting strange.
Old Feb 9, 2009 | 05:53 PM
vtxjosh's Avatar
Default warrior acting strange.
Hi all, I have a '99 Warrior that is acting funny. When it is cold it will start right up and run fine and once you ride it for a while if you shut it off it won't wanna start back up. I notice some times the neutral light will blink like it's shorting out and it will kind of make a funky clunking sound while it's turning over, but eventually it starts back up. The other day it did this and I noticed that the solenoid near the rear of the quad had a loose wire so I tightened up. Well, today I got it out and it didn't wanna start while it was cold, but it finally did and while I had it running I kinda jiggled that solenoid a little and it started sputtering a little like it was gonna die. I don't no if it matters but the e-brake is disconnected and the connector is taped up. Is it a bad solenoid or could it be something else? This is my first Warrior so I'm not very familar with it's quirks yet. Thanks!
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
hueby
Nov 6, 2015 11:34 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
