Leaking carb
Old Feb 10, 2009 | 12:34 PM
rjdad's Avatar
Default Leaking carb
I searched the category and found that my problem might be from my float or valve needle. My question is why would I have gas coming out of the drain tube located on the bottom of the bowl? I have gas coing out of the overflow which makes sense but not the drain tube. I tried to tap on the side of the bowl to free up the float but it did not work. Could I be missing something else on the diagnoisis? Thanks in advance
Old Feb 10, 2009 | 11:19 PM
honda185s's Avatar
If gas is leaking out of your drain tube then the drain screw isn't sealed shut..
Old Feb 13, 2009 | 02:51 AM
Wrenchnalldatime's Avatar
Not always 185s. If your float is sticking it'll come out the drain hose. If your needle isn't sealing off it'll come out out the drain hose. Any 1 of the three thats all the reasons
Old Feb 13, 2009 | 08:55 AM
rjdad's Avatar
Thanks I will take the carb apart, clean everything and see if it works. If not then I know that I will have to buy a carb kit.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
