wheels and tires for 250SX
Old Feb 11, 2009 | 11:35 PM
pistonhead72's Avatar
Default wheels and tires for 250SX
I have an '85 Honda 250SX, and I'm trying to decide what wheels and tires to get. I'm going with 10" aluminum rear wheels and 22X11 tires. I'm looking for a good all purpose tire, but one that's especially good in the snow. I want a tire with a flat, squared off profile and one that will help the *** end of the trike slide more easily. The stock type "balloons" on there now make the thing want to tip very easily. I'd also like to put some spacers on the back for more stability, but someone in another forum advised against them, saying that they could cause the axles to bend. Has anyone had any problems running spacers? I was thinking of going with either 1.5" or 2".
Here are some other questions I have:
ITP, Douglas or AMS wheels? Who makes the best wheel?
I like the looks of the AMS cast sport wheel. Has anyone used them? Are these lighter or heavier than a "spun" aluminum wheel? Which is stronger?
Does anyone know why the most common width for a 9" wheel is 9", but only 8" for a 10" wheel?
Here are some tires I'm considering:
Razr 2's - How are these in the snow?
AMS Swamp Foxes - Has anyone tried these?
Duro HF243 Mud and Sand (Wooly Booger copy). It seems the 4 ply versions are harder to find. Are the 2 plies durable, or should I hold out for the 4 plies?
ITP Mudlites
Kenda Klaws
Carlisle 489's
Sorry for the long post, had alot of questions. Any help would be greatly appreciated. Thanks.
Old Feb 13, 2009 | 07:32 PM
OK, too many questions? Pick one. Come on! Anyone?
Old Feb 15, 2009 | 08:03 PM
YTM_225_DX_LOVER's Avatar
ok... i'd go with cheng-shin c858s. I have them on my 225DX and they're amazing. as for your rim question, its because most of the sport tires are made for 9" rims. because they're so wide, the rims need to match. I wouldn't worry about bending your axle if u put spacers on it, Honda axles are pretty hard to hurt. the RAZR 2 isnt bad on snow, my buddy has them on his 350 Warrior.
Old Feb 15, 2009 | 10:11 PM
<div class="FTQUOTE"><begin quote>Originally posted by: YTM_225_DX_LOVER
ok... i'd go with cheng-shin c858s. I have them on my 225DX and they're amazing. as for your rim question, its because most of the sport tires are made for 9" rims. because they're so wide, the rims need to match. I wouldn't worry about bending your axle if u put spacers on it, Honda axles are pretty hard to hurt. the RAZR 2 isnt bad on snow, my buddy has them on his 350 Warrior.</end quote></div>
I think you meant C828, right? (My search results for a C858 turns up a dirtbike tire). The C828 is only a 2 ply, how have these held up for you? Do these tires have a rounded or flat profile? What diameter and width wheels are you running? I'm going to run 22X11's, do you think I should go with 9" or 10" wheels?
Thanks.
Anyone else?
Old Feb 16, 2009 | 07:58 PM
oops my bad... ya they're 828s. They're a fairly square profile, and they held up fine for me, only problem is my valves are leaking slowly. I'm running 8x10 inch rims on mine i think. I'm running 22x11-8's
Old Feb 16, 2009 | 07:59 PM
and i would run 9" rims, there's more tires for 9" than 10" with square profiles
Old Feb 16, 2009 | 08:01 PM
and the c828s powerslide just fine
Old Feb 16, 2009 | 10:03 PM
Thanks fot the input YTM_225_DX_LOVER, I appreciate it. Too bad nobody else wants to help!
Old Feb 17, 2009 | 08:01 PM
no problem... I'm actually thnkin about buying a 250SX lol... the YTM's gettin kind of worn out and i want someting a little bit faster lol
Old Feb 17, 2009 | 09:14 PM
no problem... I'm actually thnkin about buying a 250SX lol... the YTM's gettin kind of worn out and i want someting a little bit faster lol</end quote></div>
Got any pics? pistonhead@optonline.net
DFWSRT8
Aug 20, 2015 09:24 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Jul 24, 2015 11:57 AM
rcappie4
Jul 18, 2015 07:51 AM
