Snatch Block
Old Feb 15, 2009 | 08:00 PM
skinnykid's Avatar
Default ****** Block
Since I only have a 1500 # winch on the sportsman, I would like to get the most pulling power that I can.
Can the use of a ****** block be explained to me so I can use one correctly?
I would really appreciate it!!!!!!
Old Feb 15, 2009 | 08:13 PM
xplorerman's Avatar
hook it to your tree saver that is hooked to a tree run your winch cable thrugh the block and back to your atv
Old Feb 15, 2009 | 08:27 PM
Spdecat's Avatar
Click on winching techniques and download the PDF info
http://www.warn.com/corporate/...ports_literature.shtml
Old Feb 15, 2009 | 08:28 PM
Mongrol's Avatar
"Official Site Skeptic"
I've got a 1500 lb W... and I carry 2 s/blocks. Important to pull as straight ahead as possible. You may have to change anchors (trees) a couple of times to do this, but its easier on parts. And remember to pull the cable out most of the way because the greatest mechanical advantage is when its all the way out.
Old Feb 15, 2009 | 08:33 PM
rockout's Avatar
the ****** block works as a pulley system. the more pulleys the more pulling power. remember that day in science class? yeah , i missed most of it too, but the principle is it basicaly doubles the pulling power.
Old Feb 15, 2009 | 08:40 PM
skinnykid's Avatar
thanks guys! Big help!
Old Feb 16, 2009 | 05:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
one block will double the pulling power. 1500 lb seems very light to have one these sportsmans for sure.
Old Feb 16, 2009 | 07:30 AM
skinnykid's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
one block will double the pulling power. 1500 lb seems very light to have one these sportsmans for sure.</end quote></div>
It was $50 new in the box.
Old Feb 16, 2009 | 09:57 AM
dslanec's Avatar
Does the ****** block double the pulling power because you use twice as much line when it is used or because of something else????
Old Feb 16, 2009 | 10:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its doubling of the line w/ the pully like on a come a long. its the pully(like mentioned above) that adds the extra pulling power. sometimes you have to realize its not just the weight of the bike your pulling. when your stuck say in mud, theres a powerful sucktion that is present as well of the dead weight of the wheeler and if your on it theres more weight. you can never have enough pulling power imo.
