Trouble Code 25
Old Feb 16, 2009 | 10:06 AM
Rowe's Avatar
Default Trouble Code 25
I was checking my traps today and had the quad parked on an incline running. I was only off of it for maybe a minute. When I got back on and went to pull out the check engine light came on. Once I was riding and turned off the AWD and went out. About 1/2 mile later it came back on for about 20 seconds then went back off again. It happened once last week too same situation stopped on a steep incline. My first though was maybe just from being on that incline it wasnt getting fuel, or oil, but the third time it happend I was on perfectly level ground and going about 15 mph.
When I checked the codes the only one I'm getting is a code 25 which isnt in the owners manual. Any of you guys know what the 25 means?
Old Feb 16, 2009 | 10:20 AM
gatess's Avatar
25 - Transmission Input - Invalid Gear
Old Feb 16, 2009 | 10:55 AM
dslanec's Avatar
I just had the same code. Check out this thread. http://forums.atvconnection.co...tid/11/threadid/560427 . I unhooked my battery and went for a ride last night and the code has not come back yet.
Old Feb 16, 2009 | 12:56 PM
Rowe's Avatar
Thanks a alot fellas. I sure feel better now. Where did you find the code translation at? I check my connectors. The first time it happened I had just went thru some water so it may have gotten wet. Thanks again!
Old Feb 16, 2009 | 01:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i read in the manual how to check it but agree it might just be a connection issue maybe check it and put di electric grease to it.
Old Feb 16, 2009 | 01:06 PM
dslanec's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Rowe
Thanks a alot fellas. I sure feel better now. Where did you find the code translation at? I check my connectors. The first time it happened I had just went thru some water so it may have gotten wet. Thanks again!</end quote></div>
The code is in the repair manual. Not sure why it is not in the owners manual.
Old Feb 16, 2009 | 04:56 PM
gatess's Avatar
the code for my 08 are in the owners manual, Code 25 actually says Gear Sensor Signal, my original reply came from another forum that has the code listed as a sticky
Old Feb 16, 2009 | 06:29 PM
Mikka's Avatar
I had to change the sensor on mine (08/800). Originally, I thought the trouble was originating from a dirty connection but at the end I had to changed the whole module to stop the code from re-appearing.
For me, this code caused the ATV to run somewhat hotter because the electronics could not tell if I was in high or low gear.
Old Feb 16, 2009 | 06:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats kinda of weird since it shouldnt have mattered either way on what gear its in as far running hot. but who knows on these bikes.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
