Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
charging prob
Old Feb 17, 2009 | 05:15 PM
happyhunter's Avatar
Default charging prob
outlander battery not keeping charge when bike is running,replaced regulator in the summer,was showing fail on dash,it is not show nothin now,could it be regulator again even if it not showing fail,or could it be stator$$$$$, thanx people
Old Feb 23, 2009 | 03:36 PM
swampyjunior's Avatar
I do not know the exact number for an Outlander but when I measure the output voltage at the battery with the engine idling I get something around 14volts. I would assume it should be similar for yours. Check with a voltmeter at the battery.
If your voltage is good check to make sure all the connections are clean at the battery. If the problem continues remove the battery and charge it with a 2 amp trickle change for about 12hours. Check the voltage across the terminals. DO not put it back in the machine but wait about 12 hours and let it sit. Check its voltage again. If your readings are too far apart then the battery has a bad cell and will not hold a charge.
Last time I had this problem my battery would have 12.8 volts after a 12 hour 2 amp trickle charge. 3 hours later it had less than 10 volts in the battery and it was just sitting there not connected to anything! Paid $45 to replace and problem went away.
Hope this helps SJ
Old Feb 23, 2009 | 04:44 PM
thanks alot for your help,got looking and i had a blown fuse from regulator to battery,all is well.thanks again
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
BigCam
Sep 16, 2015 01:53 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
