05 polaris 800 efi running badly
Old Feb 17, 2009 | 06:22 PM
truckdriva's Avatar
Default 05 polaris 800 efi running badly
a buddy of mine took this bike in on trade and has been having some problems with it. it will run fine for .5-1 mile and then start back-firing through the airbox. he says you can turn the key off, start it back up and it will run fine for another mile or so then start acting up again. anybody run into this before and if so, what steps did you take to correct it? any help would be greatly appreciated. thanks, jason
Old Feb 18, 2009 | 06:56 PM
truckdriva's Avatar
anybody have any ideas?
Old Feb 18, 2009 | 09:47 PM
First thing that comes to mind is T-bap sensor harness shorting out . Located on top of throttle body. Harness repair kit # 2875542 First I would trace wires down to main harness for cuts in wiring and also jiggle harness to see if you can get it to act up. Have had several of these. Also rubber sleeve on sensor going into throttle body must seal properly. Hope this gets you started.
Old Feb 19, 2009 | 12:02 AM
truckdriva's Avatar
thanks, i'll check it out and get back to you
Old Feb 19, 2009 | 06:41 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
could be the fuel pump starting to break down as well as a few in that year did. imo.
SOLOLUCKY
Oct 4, 2024 09:09 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
