N0 Spark
Old Feb 19, 2009 | 04:43 PM
dgratvbikeshop's Avatar
Default N0 Spark
96 HONDA 400 fw no spark at the spark plug new cdi, coil,checked all connectors,still nothing .thanks, Dewayne
Old Feb 19, 2009 | 06:08 PM
Specta's Avatar
Default N0 Spark
check the kill switch
Old Feb 19, 2009 | 07:29 PM
Default N0 Spark
have done that also.Thanks
Old Feb 19, 2009 | 07:48 PM
Duster_440's Avatar
Default N0 Spark
Im assuming that it cranks correct?
bypass the kill switch... it could be bad or malfunctioning the bike is 12 years old....
test the stator and make sure it performing as it should.
Good luck
Old Feb 19, 2009 | 08:48 PM
Default N0 Spark
cranks over good,I have checked the kill switch with a ohm meter and checks fine as for the stator checked it also the pulser checked good too,not unless the cdi unit is bad going to check it with a running atv, Thanks for the replys, Dewayne
Old Feb 20, 2009 | 05:13 AM
HondaMechanic's Avatar
Default N0 Spark
Old Feb 20, 2009 | 06:43 AM
Default N0 Spark
done all that test also with the help of the same manual this is why I'am stumped, the only thing I found is low peak voltage was low on coil but went by book and checked in order and it said if nothing found it sent me back to cdi box,? Thanks, Dewayne
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
