Sputtering Blaster
Old Feb 9, 2001 | 09:47 PM
hondastomper's Avatar
When i ride My 97 Blaster in 2nd gear and up in Mid-high RPM's My quad sputters. It skips like it's missing spark but it isn't. I have cleaned the carb, Played with different sized main jets, The air filter,And spark plugs. But it keeps sputtering. Any info will help.
Thanks,
Matt
Old Feb 10, 2001 | 08:56 PM
brokemybanshee's Avatar
I think all blasters are like that somewhat... buy some boyesen reeds or something along those lines and it should be cured??
Old Feb 10, 2001 | 11:24 PM
dawarriorman's Avatar
try replacing the needle jet or moving it up some. the main jet only affects the airflow when the throttle is fully open, the needle is everything else except when engine is at idle
Old Feb 11, 2001 | 10:35 AM
Hey thanks for the info about the neddle, i give it a try if it continues You'll seee it posted again.
Old Feb 14, 2001 | 12:25 AM
jts's Avatar
jts
It could be 1 of 3 things. Either the reeds are shot(unlikely),or the carb is sucking air(likely), or the spark plug cap has a loose connection(likely)
ReconBayou
Oct 31, 2022 05:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
nastyblaster100
Sep 13, 2015 01:19 PM
