Does any one know about a '96 grizz 600
Old Feb 20, 2009 | 06:56 PM
jkrno's Avatar
Default Does any one know about a '96 grizz 600
the carb is leaking gas out of the clear overfill or drain (not sure which) hose and will actually drain all the fuel in the tank running or not if i dont shut the gas off and it also sputters and bogs down at about a 1/4 throttle
has anyone had this problem?
any help would be greatly appreciated
thanks in advance
Old Feb 20, 2009 | 07:05 PM
ATV_MAN's Avatar
Must be a bad day for grizzly 600's, problems allover here LOL, '96 Grizzly? thought they started in '98? anyways... your carb has a float inside, it controls the level of fuel for proper air/fuel mixture ect ect. This float has a valve and seat that controls the fuel coming into the carb, if that seat or valve is worn it can cause fuel to pour in and not stop. Looks like you need to open up the carb and see whats going on.
Old Feb 20, 2009 | 07:16 PM
jkrno's Avatar
98 my bad
so basicaly i just need to get the carb out and look at it
how hard would it be to change those out if they are bad?
what kind of $ am i lookin at
thanks for the help
Old Feb 20, 2009 | 07:27 PM
ATV_MAN's Avatar
IF it's just that part, then yes it's an easy fix, the most work is getting at the carb and removing it. The needle valve assembly is not expensive, it comes as a kit. I couldn't tell you an exact price but I'd say under $25
Old Feb 20, 2009 | 07:28 PM
ATV_MAN's Avatar
Search for your ATV HERE
and go to the Carburetor drawing... part #11
Old Feb 20, 2009 | 07:30 PM
jkrno's Avatar
i will do
appreciate the help
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
